Philio 08 motor does not work with push button
I have my rollers with the philio 08 connected, and I use a push button (standard).
But when the push button is near from the ph08, this works perfectly, but when the distance of the push button is long, like 10 meters, the ph08 does not know when the push button is pressed.
Does nobody solve this problem?
I have the same problem.
you've found solution ?.
I'm looking for. finds as I tell you.
info@zwavebarcelona.com.
Regards.
Regards.
No!! un dia empezo a funcionar correctamente, contacta con support, ya que puede que fueran ellos quienes lo hicieron.
No obstante, si tienes o te indican la solución, estaría bien que la pusieras por aquí.
Un saludo
Un saludo
I have the same problem like you. Have you found a solution?
