Power Moodule - is it connected directly to electrical or with a cable plugged into a receptacle?
Mel shared this question 11 years ago
Still do not quite understand connection to household electrical - is the power module "hardwired" into the electrical or is there a power plug you can use to plug in the power module to an electrical receptacle similar to how you would power up a Zipabox if not using a power module?
Look here:
http://www.domotica-blog.nl/post/zipato-power-module-review
You plug in "clamps" into the power modules (which is plugged into the zipabix). The clamps "connect" to your main wires.
