Fibaro RGBW settings
I have a Fibaro RGBW module and want so switch 4 relays.
I have created a few rules created to switch the outputs.
Red, blue and green work but white switched other color.
What settings do I need to make it work?
regards Maik
Hey, what is your setting in parameter 14?
Settings in parameter 14 =
I have been experimenting with using this as relays too, but I have the same issues - seems to be something with the HEX vaules (param 14) and the device actually not storing them right - actually can get it to run/output using 21845, but then it has another setting, which messes this up, namely setting 71 - which sets last color to level, when BRIGHTNESS is set to 0% - annoyning, because it goes into an eternal loop turning on/off the relay on both Red and White channel (red last used to turn off all)
Anyone out there who actually got the Fibaro to work with RGBW as four seperate relays not conflicting with eachother and willing to share show configuration?
I would like to use the Fibaro RGBW Module only with outputs. But I doesn´t work.
I use as Input/Output configuration 9999 (HEX) and also 39321 (DEC) (I also tried many others).
I also can not set the max brightness to 255. It always chages the value to -1 after saving. The same thing when I try to save the DEC value in the Input/Output configuration.
Any suggestions?
(I´m currently running 09.999.8q)
Any suggestions?
Hi Christoph. It seems like the -1 is an errratic interpetation of the numbers in the Zipato new app. If you use the old app ( https://my.zipato.com/zipato-web/Dashboard# ) you can actually store and see the correct the values.
However there seems to be bugs on the fibaro itself not acting on values above hex 8888 - so until this point I have also been unsuccesfull getting the thing to Work. Best option is to create som virtual swithces setting the values of e.g. rgb red to 255 for on and 0 for off - this Works with most ~12v dc devices/appliances.
However it would be great if Zipato contacted Fibaro to get clarification on how to get this device to work as input/output relays
