Close auAutomatic closing shutters Somfy RF module
hi!!
after very many trials I allow myself a post for a problem of closing shutters Somfy control via RF module.
I want to program an automatic closing at 20:00 two shutters
I post you a picture of the rule
thank you all for your help
Does the scene run normally? Are the values of the Humidity metre in numeric form as you have written or percentages.
The only thing I would change is to run the configure in the when block, then the humidity check in the if block.
Reason, because if the Humidity sensor is battery operated you may not get a reading for half hour or more from the sensor. Then it will not be 8 oclock either.
You do realise that the shutters will not close if the humidity reading is above the nominate 99?
Maybe you should create a rule where in the when puzzle you create a time period for the sensor to get a reading and close accordingly. Say over a one hour period.
Is anybody get the answer for me please ???
This rule doesn't work too
For my opinion your rule kicks in at 20:26.
If, at the same time - the temperature sensor will send an update with a value < 99 the shutters will go down (which is not very likely).
If the temperature sensor will send no update at this time the shutters will do nothing.
So for my understanding you have 2 options:
1) work only with scheduler and close the shutters at 20:26 regardless which temperature
2) write the value of the temperature sensor in a variable and check against the variable @20:26
This one Doesn't work I m desperate :-s
Try this
(Divise les conditions)
Try this
i m so stupid this one works !!!
i have miss the right button at top
I click the sync button on the box instead of rules :-s
thanks a lot to all users try to help me
i post a pic of the rules with time to somfy !
thank you to all those who kindly help me
