Measure energy used on house meter, what device to use?
I know there are allot of threads about this but i have trouble finding someone that says this works good and would recommend it.
One problem is that i don't have any P1 port on my meter. And i can not change it due to i live in Sweden and the grid company owns the meters. so measuring device is restricted to clamps or Eye.
My main interest is to momentary W used but of course there is also a interest to see kwh used.
the house have 3 incoming wires with total 60A divided on the wires
Many thanks for any input on a device that will work with zipato for this.
best regards
nicklas s
I'm using a flukso for this: http://www.flukso.net
It's a community driven device which has a reporting module to both the flukso api and a local api you can host.
It is possible to have 3 power inputs on the device which you are mentioning above + 2 additional meters for water / gas consumption.
I'm hosting a php api on my synology which is retrieving the data from the flukso and sending to a virtual meter in zipato.
This is very high level of course and would love to help you out as soon as you have the device.
thanks for the replay Dieter, will have a look at the device and see how it works
I'm using this one:
http://www.domotica-blog.nl/post/zipato-power-module-review
I'm using this one:
anyone have experiance with aoen lab clamp Hem3 ?
Thanks for the posts and the input. I deiced to try out Aeon labs clamps hem3 version 2
For anyone ells reading this thread in the future:
Its so far working good. I had to update the interval for values to be pushed more frequent for my requirements.
Part from that i have so far not had any problems with it.
Will post back here if i find something that is not working.
//nicklas
//nicklas
