DSC 433Mhz Sensors -- how to connect to 433Mhz Expansion Module
            Hello -
I am new to Zipato (installing system this weekend). I purchased the Zipato Zipabox 433Mhz expansion module hoping to connect 10+ DSC motion and window/door sensors (all 433Mhz) directly to Zipato system -- and discontinue using the DSC (ADT) Security panel (SCW9047)
Does Zipato support DSC 433Mhz sensors? When I attempt to add a device (using DSC as manufacturing), I get a warning that "network is not available".
Thank you.
Very good question. You will probably have to pair these using some of the existing devices from other brands. Alternatively check if you can connect zipato with the alarm panel via rs232/485
Have a look as this one https://community.zipato.com/topic/433mhz-module
Here is the answer I received back from Zipato:
Regarding your other two questions, unfortunately, I don't have good news:
