RFID Keypad - Adding tags and PIN
Selter shared this question 10 years ago
I'm trying to install the RFID Keypad. Adding the device itself was easy.
But now I'm struggeling with adding iRFID tag and PIN. I've followed the steps in
https://community.zipato.com/knowledge-base/article/zipato-mini-keypad-rfid-adding-irfid-tag-and-pin
but I get the following message after the countdown:
"Failed to learn new code" followed by "learn process timed out"
Can't be so difficult - just pressed "Home" and then (while the LED was on) entered "1234" followed by "enter"
After pressing enter the LED turns off
Same issue when trying to add the RFI tag.
I also put the keypad right in front of the zipabox ...
What I'm doing wrong?
I'm getting more and more frustrated with the whole Zipabox :(
Were you able to solve this? I have exactly the same issue here...
