light come on at certain time
Darkwing shared this question 10 years ago
I am trying to create a rule so that the zipato RGB light comes on at a certain time each day and rotates between red, green and blue in 5 second intervals. I came up with below, but am not sure whether this is correct. Would below work......... ?
8b4178dd0f68b9d66b430e4a7192f18b
now set it to this, but still not working
d755ed7a329040a457574d093c7010ee
How is the schedule defined?
you need time(now) between......
remove the if and else puzzles. Just use the scheduler with the action puzzles.
I do not think the "else" puzzle will ever run, as it is determined by the scheduler, which should automatically execute the first "when" puzzle if you have your times within the time set in the scheduler.
And if you want the bulb to turn off after the repeat, just add to the bottom of the repeat puzzle.
