Qubino Pilot-wire Module (zmnhjd1) and Zipato Thermostat
olivier34 shared this question 10 years ago
I have 2 questions regarding the Qubino Pilot-wire Module (zmnhjd1) and how it is supported by Zipato box :
1) Is the module recognized by the Zipato box ? and are all functions recognized (such as the pilot wire output, the temperature and the 3 Switches on the module (referenced as I1, I2 and I3).
2) Can it be used in the zipabox Thermostat ? since the pilot-wire control works like a "Dimmer" I wonder if it is supported as an "heating output" in the zipato thermostat.
A very big advantage of using pilot-wired module instead of "on/off" switch modules is that you keep on having a manual control on the Heater itself.
I have the same question
I have the same question. Is there any support here? this question is over than one year!!!
I have the zwave plus version of qubino pilot wire.
I have includ it easily and it work great
But the widget is displayed like a store
It is not easy to use and easy to watch (WAF)
I know pilot wire it is a french specification
but if you can make the widget (and the scene command) with 6 switch : Comfort/Comfort -1°/Comfort -2°/ECO/Freezing/OFF
With this parameters
- Comfort = 51 to 99%
- Comfort -1° = 41 to 50%
- Comfort -2° = 31 to 40%
- ECO = 21 to 30%
- Freezing = 11 to 20 %
- OFF = 0 to 10%
Thank you in advance
Hi Titof174
I am about to make a decision how to control my 'radiateurs' (I live in France) with z-wave and my Zipato system. I am planning to buy for each room a temperature sensor and would like to keep the temperature at certain levels, depending on the time of the day.
Did you manage to make the qubino pilot wire work? Can I use the virtual thermostat or would a rule work as well?
Would be great to hear your views and of course of others in the forum!
