iTach Flex wifi to IR to control AC heaters
Thierry Bousquet shared this idea 10 years ago
I read from different posts that there's some trouble with IR Air Conditionner (AC or heaters) control using Itach Flex wifi ? Problem in long IR codes that are badly managed. Is it the true or solved ?
Also i would like to control in parralel 2 AC split Mitsubishi but i want to know before to buy if it could works fine ?
My config will be one Itach Flex with 2 IR emetter connected. Each command is send to both emetters. And i will use a Zipabox Thermostat.
