433Mhz Module as remote?
Michael Kurth shared this question 10 years ago
Hey there,
is it possible to use the 433Mhz Module as remote for example for a gate?
I want to open and close my Wisniowski gate. The remote is sending on 433.92 Mhz.
Thanks for your help
No, it does not have a self learning function and only the 433 devices listed here will work with it,
http://zipabox.de/kompatibilitaetsliste-die-2/
Is it possible to add a 433MHz Device, if I already read the informations out of the gate remote?
Or is there any way to add Wisniowski Gates to the device list?
contact support@zipato.com they will be able to give you a definitive answer.
ps can you use the motor micro module to control your gate? Most motors can be controlled this way too if they have a switch input
