All temperature devices (oregon) no more working since 12 hours
All my oregon devices (temperature, wind, rain, hygrometer) have stopped updating values
since yesterday night 19-21h, this means 10 different devices.
The same here.
The same here.
Also other devices, such as chacon door sensor, zipato siren, roller shutters, and may be everything I guess.
Reboot doesn't change anything.
Same problem here! 433 mhz temp sensor stopped working right after 21:00 yesterday. My two other Z-wave temp sensors stopped working around 13-14:00 yesterday.
That might explain why my house was so warm this morning!
and mine so cold :)
I have updated the fw again (beta), but there is no changes.
and mine so cold :)
The Zipabox still communcates with the sensors/actuators. I get push messages (Pushover) when things happen. But there is no event logging.
Same problem here, applies to all units. If synchronizing, "LAST SYNC" date changes, but after a few seconds it changes back to the previous "LAST SYNC" date. It seems as if there is a server / cloud problem, is there any place one can check the status of "Zipato Cloud"?
I tried to sync my box did not work.
Then I make a hardreset.
At first moment is there firmeware 8c, a few moments later 8q and last synchronization 30.03.16. The changed device names are also gone.
We have an issue on the server side. You can't see the real status of the box as the backup got stuck. We are currently working on it...
I'm glad it's not just me!
At around 21:30 the box went offline. After it reconnected any attempt to modify a rule, or disable it, or enable it, or to delete a device, was not saved. Also, all logging ceased. However devices still appear to be working and rules are, apparently, running.
So basically exactly the same symptoms reported here.
Looks like it's back up and running again. The log is back and I just successfully saved changes to a rule.
If anyone has a problem with infrequent updates from Oregon Scientific sensors, see also:
https://community.zipato.com/topic/how-to-make-the-oregon-scientific-temperature-sensor-thn132n-work
in case it helps.
in case it helps.
