Wich data to show
Stian Sele shared this question 10 years ago
Hi tryed to search the forum, i have a question, When on the the app (android) or on the cloud.
I wonder if its possible to choose wich value to show first?
Some sensor, for example 4in one sensor.
When on the temp sensor on the device list, it can show humidity and temp, some sensor show humidity first instead of temp.
Same goes with the power consumption sensor integrated in some in wall switches.
The may show accumulated first then how much its using now.
My question is: is it possible to choose wich one its showing first ? the one you see before you click on the device ?
Sure, you need to open the lowest device subject and you will have option to check "master" the device which is the master. Is the one showing as first.
3
Thank you worked great, i thought it might be a easy fix :)
