After Power drop, Fibaro RGBW Controller stays offline
Guest shared this problem 10 years ago
After a power drop, i powered my Fibaro RGBW Controller again. But the Zipabox shows that the Controller is still offline. Also several hours later it is still shown as offline.
I know i can reconnect it by adding a new device. But this is no solution.
Hi Tobias, I have the same problem. After the power outage the fibaro can fall into offline state and cannot be controlled unless I either press the B button 3 times. This is a fibaro problem and not zipato. This is one of the main reasons why you should avoid fibaro modules in the future where you can. I did not find any solution on this on the Internet at all. The only solution is to keep this module online all the time...
Do you know any alternative z wave compatible RGBW Controller?
There is none. At least so far...
