Fibaro RGBW program launch at triple click in rule creator
Attila Hajdu shared this idea 10 years ago
I have one of these RGBW modules. With Fibaro HC2 you have an easy option to start the pre-defined programs but when you want to achieve this with Zipato (or any other controller other than Fibaro) it is not possible.
Support told me that the inputs are supported in the device manager and triple click is also supported in the rule creator, but i'm struggling to find it. Anyone has any idea how a rule should look like to allow for triple click action and thus starting this pre-difened program?
Replies (11)
I will look for this on my set up, need to look on the manual to see how they handle the groups for this device, but highly doubt that the device shows "triple click" or even "button press" in the rule creator. The only one I have seen is for the fibaro door/window sensor. I have both and never seen that option for RBGW. See attached.
I think I found a setting that might do the trick. I cannot find how to set up a "program" to run while alarmed or triple click.
Found this on and Indigo Forum, looks like also Zipato does not support the programing of custom programs, we could try with the preset ones. Unfortunately I cannot test right now, I'm on a work field trip.
Hi Alberto. You got as far as I did. Program 7is my favorite...this is why I would love to use it.
As I have touch switch via transformer connected to fibaro, no chance to use triple click action.
And I also tried Amy combination in rule.creator without luck.
What I don't understand why would Milan from Zipato say it is possible if we both are struggling to find this option.
I also was able to actiavte the programs from 6 to 10 using "SEND" command to parameter 72 in device's configuration. I think the triple click refers to a triple click on the B-Button (physical button on device used also to "wake it up"). We should be able to use rule creator to trigger and configure these programs... maybe open a request?
I just setup a fibaro RGBW controler with ikea led strips. Works beautifully, but I would like to know if any progress was made on trigerring programs other than SEND command (nice trick though !).
The only way to activate is to have a manual push button. Not possible via zipato unfortunately
What do you mean by a manual push button ? How a push button would trigger a program ?
Nope, you have to change the settings on the device so when you triple click the B-button, instead of sending NIF to the main controller it would start the selected program, not convenient at all since this device is always hidden.
instead of triggering program you can make your own program and control it.
Well, you can but it is complicated and not user friendly.
