Zipato dimmer switches for LEDs
It's extremely hard to find reliable dimmer switches for LEDs. How about you develop one that works as well as your Zipato zwave switches?
Qubino, the one and only.
Yes you're right! The QUBINO "Flush Dimmer V2" ZMNHDD1 seems perfect for my needs. Funny cause I searched for Zwave LED dimmers in Google and it did not show up. They should work on their SEO.
Thank you for the tip anyway.
I find the Fibaro dimmers work fine with LEDs.
When it comes to modules, qubino is the winner. It can handle.the widest range of LED lights.
The advantage of Fibaro FGD-212 Dimmer 2 is that it does not require a neutral to operate.
But I have had problems with Fibaro switches that would loose the connection with the Zipato box after a power cut so I tend to avoid this brand now (and their help line was not very responsive to say the least...).
I have never tried anything from Qubino yet though.
Well. See. The advantage of the Qubino is that it does not require a costy LED bypass...
Not to mention the amount of parameters you can use to configure the light. Incredigble.
Good to know, thanks. I'll try the Qubino to start with anyway.
