Slow rule filter
David Pritchard shared this idea 10 years ago
If you type in the rule filter box, it takes an age to display the results because it seems to process each keystroke immediately. Zipato should probably introduce a slight delay to the processing so that typing, say, a seven letter word doesn't result in seven filter searches (the first very slow because they generate lots of matches).
A workaround is to type the term in, say, Notepad, and then paste it into the box. The results are then almost instantaneous.
