Fibaro smoke detector 002 Heat detection
Hello to all,
yesterday I added to my system 4 Fibaro smoke detectors. Inclusion was no problem. The status report of the smoke section works fine. The transmission of the current temperature is also working fine.
Concerning the heat section I only get the message Sensor off although Overheat-eneabled is green in the settings.
So how can I activate the Overheat alarm?
Thanks for your ideas
Bernd
Think I found the solution already:
The Overheat Sensor seems to have two states: one is "Sensor off" - if no overheat and the other is "Sensor on" - if overheat. So if the sensor shows a green "Sensor off" it means it is active and working
Bernd
Bernd
