Configure
HB shared this idea 13 years ago
If I add a Scheduler-puzzle and click on configure, there is a Name and a Description field.
What is the reason for these two fields?, what is the usage?
Then when done with my configuration, on the puzzle-piece it just shows the text "configure".
SOLUTION
Change so that instead the text "configure" after I have done the configuration the text from Name or Description is shown on the puzzle instead.
That way it is easier to know what the Scheduler do (if I have entered some good name or description)
( I think that a generated text like the summary will be to long, otherwise that could have been shown, , but there is a Name or Description that can be used)
The same way with SEND-puzzle change the text "configure" to something else when it has been configured. ex: "SMS to John Smith"
or add a field where I can enter a text (a Name or a Description field or something else)
There is also other places where a similar solution can be done to make the puzzles more understandable! (ex: http, socket)
With puzzle variables the text is changed from "select" to "name of variable" after selection.
So I think it is the same with "configure" after a configuration is done, change the text!
Cedar Falls Tree Service is a full-service tree company that provides expert tree care to residential and commercial customers in the Cedar Falls area. There is https://treeservicewaterlooia.com/ offers a wide range of services, from tree trimming and pruning to removal and stump grinding.
