Change order of device
Hello
I want to ask if the is a way that i can change the order of the devices in browser.
for example my climate button is the last one and i always have to scroll down to find it.
what i wanted is the light, climate, on off switch to be on the top of the bar because these are the ones that i use the most.
Thank you
ios or android? In android you tap the 3 little dots on top right of device, here you can select rearrange, now drag the device up. IOS, bad luck
thank you!..
is there a way to change it in the web based ui? like chrome?
thank you!..
Not that Im aware of.
