White Zipatile - Black Display?
Robert Hercz shared this question 9 years ago
From what I understand from other posts, the white display with black text on the white Zipatile is advertising mockup only and that the display _cannot_ be configured this way, leaving users with a nice white frame with a pitch black center display.
Question is: Would it work to have the display "always on", i.e. disable the sleep/blackout to make the center less dark, or would that hurt the display and create burn-in?
Hello Robert,
I have a white Zipatile myself. And yes, screen is black. You can set the screen to never sleep through Android settings. But I am affraid Zipato app for Zipatile is black background.
Hope this answers your question.
@Pablo, Thanks for confirming that the screen cannot be "inverted" to black on white.
The question which then remains, is if the screen can be damaged (get burn-ins) if left on for ever?
If anyone, than only Zipato can answer this question. They know what display was used and whether it can candle constant ON state.
As the others have confirmed, white zipatile app is black, even though I think it was also false advertisement should be to big of a deal for them to change the theme to white, just probably not a priority for them.
3
I just received the white one and was expecting that I could set a theme in the device. Unfortunately it isn't the case. Hopefully they will add a white team soon.
Di you Tyrannen to invert via Accessibility at Androide Settings?
