Bindings, where are the Zigbee options?
Adrian Van Der Heijden shared this question 9 years ago
In the old Web Control center you could bind almost anything to anything. Now bindings all seem restricted to Z-wave devices only, Why? Where are the options of binding a simple on/off open/close zigbee device to a virtual or enocean device?
If you referring to the assotiation manager limitation, then there is another way. Go to a device you want to bind and at certail level you will find the correct bind options separated by different event.
For example see attached screenshot. These option I have when selecting a virtual sensor (1 level below root).
ad4f19868eb99d55ecc9b255a3920152
Thanks Attila, but I know this, there are just nothing to bind with a Zigbee device or to bind to a zigbee device. eg I can use a virtual device and bind to an enocean or zwave device, but zigbee devices do not show up. I am wondering why? especially since Zipato are bringing out a range of zigbee deivces now.
Ok. Well this case need to open ticket...
