Adding ip camera
Lars shared this problem 9 years ago
i cant add any ip camera, and i do not onderstand whay...
Zipato detects the camera i cant add it what do i have to do to add the camera their is no add button? and i cant continue the add wizard?
Hello Lars, instead of using the wizard, try typing the IP:port manually. Then go to the device manager and configure the rest of parameters there
you meen in the wizard use ip scan and add IP and port than save? the wizard answer is: "Failed to save camera"
(Ipcam01.jpg)
I try to add is manually, the device is shown as IPC and has nu and punts to edit.
Files: IPC.png
somhuw i am missing the boxes to add the camera in my wizerd.....
Hello Lars,
I will try the following:
1.- Go to Device manager > Add > IpCam > IP Scan > Enter your IP:port
0d7b8d999de21168bc7df49c5a8a5f2e
2.- Go to device browser > Cameras > Edit camera configuration > There you can add the user name, pasword etc
5c4813238c8f4fc006992cf217fc1854
