Rule for temperature change
hello,
is there a way to trigger a rule when temperature changes?
I have a POPP thermostatic valve, which has a temperature sensor and I want to start a rule with WHEN temperature changes...
Temperature/POPP valve is listed under meters, not sensors
how can I achieve that?
thanx
Something like this should work: https://snag.gy/Ixu0ov.jpg
You could also create a virtual thermostat
yes, I have a similar solution. but the trigger is probably time, not temperature change. it's called regularly by rules engine, even when nothing has changed
Hi Martin,I'm not sure if it's just a time trigger. I've always assumed that the rule is executed once a new value is received by the controller from the sensor. The sensors I use can be set to only sent new values after a certain temperature change (hysteresis), I'm not familiar with your POPP device.
