Delete contact in user options
Frankie shared this problem 13 years ago
Not a Problem
Hi, I try to delete a contact in "user options" but it does not work. If I go out general options (synchro, refresh or nothing) and go back again in "user options", the deleted contact is back.... What's wrong? Rgds, Frankie
Replies (7)
Any feedback from zipato team?
You can't delete contacts which have alerts or messages set to them. You should get popup message with info if you try again.
Sorry but it still does not delete my contacts. I am sure they are not used in a rule. Moreover, as a test I have created a dummy user in "user options" and then delete it. After a syncro, the dummy user is back...
Are you talking about contacts or users? It's two different things?
Hi, I am talking about contacts (3rd tab) of "user options"
When I try to delete a contact I have the following message :
Failed to delete contact.
If you realy want to delete this contact, please make sure it isn't used in any messages.
But I'm quite sure this contact is not use in any message ...
Nenad, anything new on this side?
Rgds.
