new UI Zipatille
Zipato guru shared this question 8 years ago
The new UI is available under 2.2.5 or under 2.2.6.
which one i shall install.?
2.2.6. should be the only one available now. The difference is only a small bug fix.
Hi sebastian so it was just released now from 2.2.5 to 2.2.6 as i've seen that the best answer was the 2.2.5 and then when installing i found the 2.2.6 .
Thanks Sebastian!
I really appreciate your support!
