Calibrate Fibaro FGR-221 roller shutter controller
Jarle Sjøthun shared this problem 13 years ago
Not a Problem
Hello!
This weekend I have used many hours to figure out why I can't calibrate the Fibaro FGR-221 v2.1-2.3 motor controller. I have the FGR-221 to control my valve motor Belimo LM230A. I want to have the motor stopped at the percentage I choose in the Zipabox. The operating manual for FGR-221 says:
"It should be noted that after proper adding the Roller Shutter Controller to the Fibaro system, it should be calibrated. The calibration process involves performing two complete cycles of opening/ closing the shutter. Properly completed calibration may be verified by setting required position of the shutter using the icon e.g. 30% of shutter opening - the actual opening should correspond to this value/position."
After I have added the device to Zipabox, and then push S1-button to perform a complete cycle the motor stops after about 1s. Is this a known problem?
If I turn off positioning in device manager I manage to fully open (on) or fully close (off) the valve, but not to stop in between. Do you have a solution for me?
Regards,Jarle
Link1: http://www.zipato.com/UserDocsImages/_SHOP/user_manuals/Fibaro-roller%20shutter%20FGR221%20v14%20-%20v17%20ENG.pdf
Link2: http://www.belimo.ch/pdf/e/LM230A_1_3_en.pdf
Hi, did you find solution for this ? if FGR-221 is not working, that you are using to control Belimo LM230A ?
Rimas
