Adding Doorbird problem
jules grasso shared this thanks 2 months ago
I bought a doorbird IP205 but i can't add it on my Zipitile.
I have a cluster with one zipabox and one Zipitile. I want to add it on my zipitile so i follow the instructions, Add new device, Doorbird, And i have a probleme There is not Door bird D205, a D204 yes but not more.
Finnaly i tried to add it in Doorbird D101 just in case and i found it ! but i can't save it, "save failed all the time"
I join you some screenshots.
On doorbird aplication everythings are fine i see and i heard (from the zipitile), the bell of door bird is ringing.
Thank you
Jules
Comments (5)
Hi Jules,
first you have to enable ONVIF in your Doorbird.
regards Helle
Ok thx for your answer i did it but nothing change what's the next step ?
Thank you
jules
Hi Jules, over the weekend I have successfully added a doorbird D101 on the 1st try. I suggest to raise a support ticket with Zipatol
yep this was my second idee thx
Hi guys,
Finnaly the support awnser me....
The 205 moddel isn't supported by zipito.
Thank you.
