Balance Due problems on Invoice: QuickBooks
Kaira Thompson shared this thanks 27 days ago
BalanceDue problems on Invoice: QuickBooks is luckily not anissue, if you know the reason behind that. The balance due you are seeing atthe bottom is not the total due balance, it is the balance for that particularsale and will not be included to other transactions. But if you want to change theview or the total due balance at the bottom, then follow these steps:
® OpenQuickBooks online and go to the ‘Settings> Custom Form Styles’.
® Thenin the invoicing template, select Editand go to the Content tab.
® Inthe upper side of the appeared page in account summary, tick the box next to Show on Invoice.
Read More: - Quickbooks Customer Support Number
