Danfoss&Zwave termostates + Zipatile = Automated floor heating
Tomas shared this thanks 7 months ago
Hey,
Do we have any solution with Danfoss and Zipatile Z Wave for the floor heating? I have read about the virtual thermostat pro version, does it really work? Is exist any more option?
Comments (5)
You can add Zwave Danfoss RS thermostat (it is with battery product) in room also you should use double switch or 220V Output module to control valve. It works nice. Or you can use Heatit Thermostat it can control valve directly. Heatit Thermostat has 220 Volt output. and it include floor sensor.
This is danfoss rs linkhttps://www.vesternet.com/z-wave-danfoss-temperature-sensor
This is heatit link. You dont need thermostat pro
https://www.heatit.com/heating-control/floor-heating-thermostats/heatit-z-wave-thermostat/
did you have troubles with including more then one danfoss RS thermostat? i have a few projects wher one or two RS-Z thermostats work fine, but a few others only give the temperature and are not adjustable.
we didn't see a problem including more then one Danfoss RS thermostat. But sometimes RS Thermostats have calibration problem. Our partner gave some of them warranty replacement.
thanx, I'll try again
