exclude / include a device without setting parameters to their default values
Michel shared this thanks 15 days ago
I need to change a parameter (parameter 1 : value 5) on a qubino module 0-10 V
In the module datasheet they says :
After the value of the parameter is changed to values ... first exclude the device (without setting parameters to their default value) wait at least 30s and then reinclude the device.
I tried to do that with zwave parameters :
Remove node. Then 30s later : add node but I am not sur it is the good way because the result is not ok.
Comments (1)
Definitely should work. Change this parameter to a different value, then change back to what you want and then exclude wait and then include.
Dont exclude holding button longer than 3 seconds
