Fibaro FGBS321 Universal Sensor v2.1 - v2.3+
Armin Barnick shared this thanks 1 week ago
Hello have 3 pieces in use with temperature sensor. My problem i can not change the sampling and temperature display intervals. I only get a temperature value every 26 minutes. But I would like to see if the temperature changes and not 26 minutes later. The transmission of the status values of 26 minutes is too long.
Comments (4)
you have to modify the parameter 11 and 12 in the parameters of your device.
The parameters 11 and 12 when I enter he tells me the are already present.
Change 12 to 0 If the value is set to 0, then information about the temperature will be sent every time, immediately once the readings have been taken from the sensor.
I have already set the value to zero. So parameter 12 size 1 and then value 0. But it brings no change.
