Fibaro new motion sensor - Planned support ?
Simone Biagini shared this question 6 years ago
Hi.
There's a plan to support the new interesting sensor from fibaro?
thanks.
Support will be added once we get our sample.
Comments (26)
I'm pretty sure there will be (of course I am ;) )...we first have to wait for its availability, then Zipato's team will get one and make it compatible (or rather make the zipabox compatible with the fibaro sensor ;)
Nice sensor!
I will get one for testing very soon too.
Any updates on this?/do you have it Zipato? ...i'm about to order 3 of them.
Next week we will have them here...
Ok, great. Thanks for the update!
I'm about to place my zipabox system order.. And I don't know if it's the time to buy that sensor or not.. have you a support timeline?
Can I buy it or it's better to wait?
@Simone: as I could see with precedent devices, when as they get it, it won't be longer than one or two days to make it compatible.
You can safely buy your zipabox, your fibaro sensor, and begin your installation ;)
Welcome to the "Zipabox community"! (for real this time, I know you already participated to this forum ;)
we got it today, we are testing it now....
Great news! got mine yesterday -:)
It seems to work. Now learning all the possible settings.
Thanks Zipato.
...WAUW what a fast support. Great great great!
It's working great but where can i find the shock/earthquake option/value?
Hello anybody there?
1 more question
FILES%2f2014%2f04%2ffibaro-motion-sensor-set-lux-report
Should this be seconds (not LUX)?
I think the lux paramenter works in that way : if luminance difference is +-10 on the last value >> report value.
So.. if lux is stable in 5 hours, no lux reports and then more battery saving.
too little value > too much reports > lot f battery eating.
Greetings,
HeroS is right, this is a typing error, it should say "Seconds" instead of "Lux". We have corrected this.
Hi Marko,
Great and this question...
Yes, the motion sensor can supposedly act as a simple earthquake detector. This is achieved by setting the tamper sensitivity really high. We do not display tamper sensors by default on the dashboard.
The second problem is that we interpret tamper alarms as simple ON/OFF values and not as dimensionless values.
I hope that this will be changed..
mmmm where can I find the temperature and lux data?
I see the motion sensor, I see that a meter with two option exist.. but how to see that data? I need to create a thermostat? but I have noting to use as heating or cooling device (and they are required).
You need to put a value in the lux and temp report interval field (in the config tab).
Look here:
https://www.youtube.com/watch?v=t7w7Z13B_Sg
I configured the temp/lux report field, every 3 hours report (10800s).. but I'm unable to see temp/lux report in the event log (only the first time I activated the sensor, and only temp). Temp was not in event log, but seems available in the widget.
Actually, after ~12 hours I see a lux value (I opened a ticket) in the widget, but no report on event log.
How to configure earthquake sensitivity high? I want to use it with alarm (home mode).
Sensor will be in the center of house so i don't want to get alarm if it detects motion i only need earthquake data.
How can i make rule with earthquake detection?
Set G FORCE param to 1 and its very high sensitivity now.
How can i make rule with earthquake detection? still problem
The Earthquake option is not supported through the rule creator/not shown on the dashboard.
Don't think zipato is going to support is. But you can contact support about this: support@zipato.com
Also notice that even Fibaro is not supporting this feature yet.
