Fibaro Motion FGMS-001 (Z-Wave+) V3.2
Sergey shared this thanks 12 months ago
I connect my Fibaro Motion FGMS-001 (Z-Wave+) V3.2
with my Zipato. I can see all measures like temperature and luminance. I want to create a rule with the temperature or illumination. I can't see the measure temperature in the rule creator like you can see in this images.
It is defined as an unknown device (0.jpg).
Zipato does not support Z-Wave+ ? Zipato mention that this sensor is supported.
This topic has already been: https://community.zipato.com/topic/fibaro-motion-sensor-fgms-001-temperature-rule-creator
There is no answer for the ticket yet ...
So, what is the problem ?
thanks
Comments (3)
Many thanks to Zipato's support, they fixed everything!!!! This sensor works! The problem was in frequency RU. I like Zipato!
Frequency RU ?! can U explain what was the Zipato's answer ?
thanks
Me too I would like to know because when I add the Fibaro it is not seen as Fibaro Motion FGMS-001 but as binary. Altough I'm able to see all node and Temp, Lux are working.
But I dont have any configuration setting
/d67d4fb7ba99fd912a11406b69687fd0
Also I want to use the temp sensor in virtual thermostat but it is not in the list under thermometer.
See screenshot from the device.
/d092e6bb988255999764caff7c25cc90
/36726ab644c991972fe8d45f1ce34961
/204c4dccd39b31894a89d12161f489b0
Why the temp sensor called "Bedroom Djimo Temp" is not visible here?
