FINALLY figured out how to successfully install google services on my Zipatile!
matthew t shared this idea 3 years ago
I have now finally installed google services to get the apps that required it as dependency to install and function correctly. No need for a USB cable, as it was done from within apps. now my apps update correclty and i can finally implement voice commands into google now and tasker.
Comments (6)
pls share this information...
Good work...
Matthew, please share step-by-step instructions!
once your zipatile has been rooted with kingroot. download Flashfire and install it from the dropbox link i provided.
secondly, go to open http://opengapps.org/ and make sure to select (ARM) as your platform, not ARM64. anything other than ARM will cause it to fail. select Android (5.0) and then whatever variant of google apk package you want. i selected micro, becuase it was the most minimum sized package available with ok google.
once the flashfire apk is completely installed on your zipatile, and you've put the Gapps package you want to add to your zipatile on either your SD card or internal storage. "i kept Gapps on the sd card because it was easier to find when flashing the package through Flashfire." open flashfire, hit the rid circle with the white plus symbol in it. it will open a menu of options available. select the flash option and it will ask you to select a zip file. once you select the Gapps zip you added, a new popup that will included two available options with two boxes you can check where to install them. make sure to check both boxes.
once that closes, hit the flash button and let the magic happen.
it will restart the zipatile and youll see a bunch of files flashing down the screen. DONT TOUCH ANY BUTTONS OR LET THE ZIPATILE DIE. once your done installing Gapps, let the zipatile load, it takes a few minutes for it to be used again.
from now on, being that these are installed in the system files, you wont be able to do get normal updates from zipato, yous have to from now on, youll have to let the OTA system update fail and then follow the same steps through flashfire to install OTA's. you can google "how to flash system OTA's with Flashfire"
https://www.dropbox.com/sh/02lj4gicr2xd2mx/AAAFOABhk_qLodAspZWi1N-za?dl=0
anyone tried that? is it working?
Dropbox package doesn't exist now, link should be down,
Is-it possible to have a new one?
pascal, heres a new dropbox link.
go to http://opengapps.org/ to download the google apps. make sure you select, arm, as the processor and 5.0 as the OS model. i have "nano" Gapps, as i dont need all the fluff and the extra programs eat up the limited virtual memory and slow down the zipatile. and the size of the package is perfect, as it gives you just the basics
https://www.dropbox.com/sh/0v0zhlhgd8d00pa/AAD6Ycv6unfWOi4PmKGVh1B5a?dl=0
double post
I have try 2 times to root with Kingo root but still crash at 90%
Try Cycling the power on and off on the zipatile. Kingoroot is the only root method for the zipatile. Me and a few other users have used this exact same method to root the zipatile.
Matthew , can you provide the apps again to succesfull install playstore...?
here's a link to my dropbox with all the files you'll need. just follow my prior directions by adding these files to a folder on your sdcard. now kingo root might fail the first or second time, but thats normal. it WILL work, it just takes a few times for it find the exploit. there have been many people that have used the same method, including myself. also zipato support informed this is how they rooted their zipatile to show some features in one of their youtube videos...
https://www.dropbox.com/sh/j2aff4izri1gt5d/AADHZbl-6b334nJdZzIuQLk2a?dl=0
new kingo root cannot root the zipatile.....
need to find another way
Kingo gets stuck at 90% tryed i gues 30 times now....
I am having the same problem with Kingo root stopping at 90%....
I gues Zipato closed the "gap" wit later firware updates...
I didnt found an solution to get root yet...
anyone able to root zipatile v.1.4
Okay. The above links no longer function. I want to root Zipatile to add items like Duo, Google Music,, etc. Help please.
@Willie, @John - it's no longer possible, unless someone out there is withholding the truth :)
