How to set Fibaro module parameters?
Bambam shared this question 9 years ago
Does anyone know how to change the Fibaro module parameters that are mentioned in the manual? Can it be done using the Zipabox?
I copied a part to give an idea what I'm talking about.------ start snippet ------------Parameter no. 1 - Activate / deactivate functions ALL ON / ALLOFF. default value 255Available configuration parameters:255 - ALL ON active, ALL OFF active.0 - ALL ON is not active ALL OFF is not active1 - ALL ON is not active ALL OFF active2 - ALL ON active ALL OFF is not activeParameter no. 3 - Automatic turning off relay after set timedefault value 0Available configuration parameters:0 - Auto OFF disabled for both relays1 - Auto OFF enabled for relay no. 1. disabled for relay no. 2.2 - Auto OFF disabled for relay no. 1. enabled for relay no. 2.3 - Auto OFF enabled for both relaysParameter no. 4 - Time after witch relay is automatically turned off. default value 20 (200ms)Available configuration parameters:[1- 255] (10ms – 2,5s) time after relay is automatically turned off.Parameter no. 5 – Time after witch relay no. 2 is automatically turned off. default value 20 (200ms)Available configuration parameters:[1- 255] (10ms – 2,5s) time after relay is automatically turned off.---------------- end snippet ------------------
3
Just have to go on configuration tab, on the device folder icon
... unless it is a fibaro FGS211, for which it seems some firmware versions are not recognized
I am currently playing with the FGD211 (dimmer), but also have the FGS211. I found the device manager under Total devices in the general section (upper left corner) of the dashboard. This shows me the device manager, and clicking the device (not the buttons) indeed shows the parameter options. Thanks guys!
