IKEA will launch their smart plugs in october
jampe shared this thanks 10 months ago
https://teknikveckan.com/nyheter/ikea-gor-kaffebryggaren-smart-i-host/
I hope that Zipato engineers are wake and make those compatible as soon as possible.
Comments (27)
Only 9,99€, I will try tomorrow:
https://www.ikea.com/fi/fi/catalog/products/90356166/
Jampe, please report how did you succeed :)
I had 1.2.29 didn't work but after updating to 1.3.13 it started working. 1. Reset Ikea plugin 2. Plugged it in and after that second reset and Zipabox found it and added. 3. Name the plugin because Zipabox dont know what do it: Generic On/Off:Plugin:OnOffSwitch and voilà. Remember sync and I also logged out of the controller almost on every phase. Plug in makes an another OnOffswitch but it dont work so rename only those which work and exclude all the others
Hi! Can I use only the zipabox with Ikea or do I need the zigbee module too??
Hi, Ikea Trådfri works with Zigbee protocol. You need the module
Can I use only the plug from ikea or do I need a ikea remote or something?
How do I connect the plug to my zipatile?
Thanks!!
Hey, thanks a lot! I think I'll visit Ikea also :)
I purchased a pair of these. Works like a charm - thanks a lot :)
Hi Guys,
I have a problem with my new plug. Added it and worked fine but after that I cannot do anything
Any tips and trix?
Hi, here are more pics, this is the trick: Name the plugin because Zipabox dont know what do it:
1. Generic On/Off 2.Plugin 3.OnOffSwitch.
Now there was also a variant with a remote button; 19,90€ I purcased one for trials and could connect the remote to Zipato, but only as a dummy. I tested several device type settings like Generic On/Off etc. It appears to the rule generator, but when assigned to a rule, nothing happens when pressing it.
Situation looks like with the other Ikea controls: the round remote and motion detector. They will also connect to Zipato but that's all. Or has anyone made them work? (I have not tested them recently if a support added). I keep testing and will report if success.
648b24256b9e284676377abc2c47a24d
At this moment use firmware 1.3.13 (latest release). With firmware 1.3.20 (latest beta) the ikea plug is included with no attributes and pretty useless.
I did the above with the desktop App. On the android phone it is a no go.
I tried to follow Jampes guide: 1. Generic On/Off 2.Plugin 3.OnOffSwitch.
I can add them but I dont get them to work in the app. There's just a dash where the On/Off symbol usually is.
I'm om firmware 1.13.61, got the ZigBee module and works like a charm with the Trådfri lights.
What batch the Trådfri Smart Switch is from I dont know. It says the number 19972 on the Switch and it says AA-2005567-4 on the box.
Any suggestions?
None. Currently, with the latest firmware (.61/.62) it is not possible to include the plugs in an usefull way. I have done it with firmware 1.3.13. That was succesfull. Last week I raised a ticket for that: answer was more or less that it was a bug that i could include it with 1.3.13. However some ikea stuff is in their lab. Probably before the end of the year they are supported.....
Good news I think. This morning contacted by support. They are doing some testing right now! Keep you informed!
Thank you John for the answer.
So a bug and the end of the year.
Well, I thought IKEAs plug was a little to good to be true😜😂
Hi everyone.
The IKEA smart outlet should be working normally now.
In case you encounter any difficulties please open a ticket and We will see what we can do to help.
Kind regards,
Borna
I can confirm this. I have included 7 plugs without any problem. That was good news from Zipato!.
I start playing...
Typical, I returned them this morning😏
Well, I kept one. If I succed with that one I go and buy more. Thanx for the info!
Tried the one I still have, works fine!
They are 99SEK (less than 10 euro) here in Sweden.
Thanx Zipato!
Hi. Good news. Zipato, how about the IKEA remotes? Any chance to get them working in near future?
We have support for IKEA TRADFRI Remote Control. In case you are having issues with those. Please open a ticket so we can investigate more thoroughly.
Kind regards,
Borna
Hi. Thanks for a reply. I have managed join device but it doesn't work in rules. I'll try again and open ticket if it fails.
Thanks. Janne
Hi Janne,
My Trådfri Smart Plug works fine in rules.
Best regards
Erik
Hi Erik
how do you add the outlet to the Zipato?
ignore that - spotted the little hole in the bottom. Paperclip in and it connected!
