Install a external DS18B20 temperature sensor on Zipatile
Peter Heidkamp shared this thanks 2 years ago
I want install an external outside temperature sensor on my Zipatile.
For that, the Zipatile can connect with DS18B20 sensors.
But the spezifications of these sensors has three connections, normaly: red(VCC), yellow (DATA), black (GND) and the Zipatile has only two connectors + and -
How could that work, how can I link that?
- = GND
+ = DATA ?
x.x Volt = VCC ?
Thank You
Peter
Hi, connect 1and3 contacts and connect to - , pin 2 +
Comments (8)
Very bad description... What do you mean?
Kenan Bey selamlar,
Konu ile ilgili desteğe ihtiyacınız olur ise destek@zipatotr.com adresine mail atabilirsiniz.
Zipato Türkiye Teknik Destek Ekibi
Thank you, that works:-)
And could I connect more than one sensor to that input? If so, how? Thanks.
Hi dario,
have you managed to connect multiple sensors on the same fibaro universal module ?
Thanks !
Gab
DS18B20 is one wire digital sensor normally... But i do not think so we can use multiple sensors on zipato...
Hello Kenan
There is a lot of solution in Zipato. You can use FGBS 001 with 4 wired DS18B20 sensors. Also you can ask your Supervisor in Zipato Turkey. They can send you document .
