Lan connection zipatile
does anyone know which micro-usb port on the rear of the zipatile to use the cat5e lan cable adapter on? i can't figure out if goes on the power or other usb port..
It is the micro USB port. There is only one. You need to buy the adaptor (zipato sells it under their own brand.)
Greetings,
The other usb port. Power usb port is for charger connection only.
Greetings,
great! i wasn't sure. as the second micro-usb couldn't be used for transfering data or usb debugging..
I only find one micro-usb port (near the power).
Where is the second port?
The first port is power and The second port is only for a Lan adapter. USB debugging had been disabled by default. I've already asked about this..
Arggg...
I try to have a better song as I use my Zipatile to say some TTS informations.
So I have buy a USB Audio card. It works perfectly on my phone or on my tablet, but impossible to use it on my Zipatile.
Arggg...
id reccomend adding a bluetooth spearker/microphone.
like this. https://www.amazon.com/VeoPulse-Bluetooth-Car-Speakerphone-S61/dp/B01J5DDEBY/ref=sr_1_19?ie=UTF8&qid=1478724775&sr=8-19-spons&keywords=bluetooth+speakerphone+with+mic&psc=1
