More than one camera stream
tomu shared this thanks 10 months ago
I would like to open more than one camera stream at the same time in the web control center.
It is possible to open a second window of another camera stream, but the stream is not loading. The window is just empty while the first stream is running fine.
Comments (3)
They should be unrelated so it should be possible
No, it´s not working. Attached you will find a screenshot.
In this screenshot I opened first the stream of "IPC Doorbird" cam. This works without problems. After that I opened another stream, but the stream is not starting.
If I do it the other way around it works with the other cam but not with "IPC Dorrbird".
I use Chrome as a browser.
Files: cams.PNG
Evidently it is chrome related. I managed to get it running without problem. Im using mozilla.
