Problem with Doorbird app and Zipatile
tomu shared this thanks 11 months ago
I have a Doorbird D101 and Zipatile.
The problem is that the app needs to run permanently in foreground, otherwise I don´t hear when someone rings. But if the app is in the foreground the display is always on (I guess that comes from the Doorbird app).
How did you configure the Doorbird with Zipatile? Is there any best practice?
Comments (12)
Doorbrid is badly implemented, and does not always work well.
Also doorbird is telling that there is an update,and you alsways have to click ok first, very anoying.
Best practice is when the doorbird app pops up is to close it afterwards.
Use the follwoing script , to turn on the screen of the zipatile on and off when somone pushes the bell.
5da699a20e43af1796b001ade92d49c5
Hi Dimitri,
thanks for that! I have already a rule similar to your rule.
But if I close the app after I used it, I don´t hear the doorbell next time because the app is not started. The app must be in the foreground all the time, otherwise the doorbell sound does not play.
hmmm, for me doorbird alsways pops up. i need to close it , otherwise at the next doorbell push the screen in doorbird is white .
I have the same issue - unless the Doorbird app is in the foreground, there is no doorbell sound.
That is not the only issue - the reliability of the audio is minimal - usually there is no useful audio between Zipatile and Doorbird.
I hope there are some fixes for this - I have built my house to suit the Doorbird, wiht the Zipatile as the intercom for it, and it certainly doesn't work at present - very frustrating.
Dave
for me the doorbird app stopped working correctly.
The app itselfs works on the zipatile if you start it.
But it will not respond anymore when you push the doorbird bell.
So no screen state and app not starting. Very frustrating.
same problem here.
ring -> zipatile open app no ring sound. Very Very frustrating.
i think doorbird have updated their api and now Zipato need to update their integration with Doorbird again. So try opening a ticket and see what support say. Good luck.
Just install an good old Doorgong like I did :-D
regards
Have no more cables :)
buy the Doorbird Wifi Doobell. Works very well.
its also 150Euros! That's nearly half the cost of a Zipatile!
Has anyone got this working - i cant understand why the ring doesnt happen wth the app in the background. Works fine on my phone and other android tablets.
