Problem with rule about hrt4 asr zw actuator
Alfredo De Felice shared this problem 9 years ago
I've this rule:
-When actuator(hrt4 asr zw) is off
-Send mail
For 1 week all ok, one mail when actuator is off!
Now, i recive 24 mails a day....it's terrible! Why? My rule is basic and i just delete and ricreate a rule but mails are 24, one every hour.
Replies (11)
Did u check the event manager? To see if it goes off every hour.
In the event box, the sensor is check every 3-4 minutes and it is off. What is a problem??
how can i create a rule that i can ignore if the state is the same??
i'd like a rule:
-if actuator is off
-send email
if the state of actuator is again off
-don't send email.
The problem is that the device send every one hour its state
Help me, please
Don't know what the problem is maybe something has changed.
Try something like this:
Rule 1
When actuator = off And NOT variable actuator = 1
send mail
Set variable actuator to 1
Rule 2
(to reset)
When scheduler (pick time)
Set variable actuator to 2
HeroS,
my problem is this:my actuator boiler sends its status every hour. So, not being able to modify this parameter, I need a rule that checks if the state is on or off, send me an email with the status of the sensor, for example off and not send more emails until the state does not pass on. same thing, if the sensor is on, send me an email, and does not send another until the status does not switch to off. Would you be so kind as to post an example of a rule? thank you very much
I don't have a heating so can not check if this works.
But try this:
When actuator = any
If actuator = on And NOT variable actuator = 1
send mail
If actuator = off And NOT variable actuator = 2
send mail
i try and arrive only mail when i stop (OFF) actuator. Why??
6pHs4e7Z0UV3bhMD2ull
this is a rule that works only when i stop actuator.
And when i try with out the not variable ?
i try, no work, only when i stop actuator. please, help me.
