Proper set up of Heatit thermostat via Zipato - Electric heating system
Vlado .Horvat shared this thanks 2 months ago
can somebody help me to configure thermostat, since I'm not most skilled person in this area.
I have Heatit-Z-TRM2 thermostat which has floor and thermostat air sensor. As first thing I paired thermostat with zipato and created virtual thermostat.
/3df266e3c16e5cf24c884465c86e05c3
/1b7ef7664dfb4b1c731d11242a18c0c5
Then I manually changed the mode of thermostat from A to AF, because I want to let the floor heat based on air, but not allow the temperature of the floor to get on higher value than 27 degrees(also configured manually inside the thermostat - FHI set to 27 degrees).
Can you help me configure following part of thermostat config?
/0e3dcbe837bfa144e618425cd4e32c49
Also attaching list of particular parameters:
/1b869b53546293c4dca0556723a2fe35
/9477541f26f2135df7ed55b84f17fdf5
/f42034680ac2f3d365bd250e7d68074f
/996e00c2becf91a2ca6bbed6841862cd
Thanks in advance,
