sricam connect
FRACHE shared this thanks 7 months ago
Hello!
I try connecting my Sricam015 on the zipabox. I do not know which information indicating in the camera data :-( .... camera does not work with my zipabox :-(
Please can you help me?
Thanks in advance,
Nicolas
Comments (1)
HI Nicolas,
I have the same problem with my sricam cams. It seems that the viewer that Zipato uses to view the video stream doesn't support the avaiable sricam stream.
Sricam is able to stream the image with ONVIF1. For example the VLC viewer is able to work with the onvif1 stream from the sricam.
Check https://www.ispyconnect.com/man.aspx?n=Sricam for the stream settings of your device.
Br,
Walter.
