thermostat problem
Marius de Jong shared this thanks 18 months ago
Hello
My virtual thermostat pro in the living room stopt working. when the set point in heating is 20.4 and the temperature goes below that temperature it does turn on a switch but turns it of wile the set point is not reacht as a result the temperature drops and its cold in house. But when I set the thermostat to cooling it start the cooling output wile the set point is 24 and the temperature is 19 so it should not start, it worked fine for more than a year but now it stopt working. I created a new thermostat but it gives the same problem.
does anyone else have the same problem?
Comments (2)
I have the same exact problem. It just shuts off and have to start it manually.
I have the same problem. Works usually well, but sometimes it does not hit the heat on.
