Time triggered scene
Rick shared this thanks 3 months ago
Hi I try to start a scene daily at a specific time.
In this case simple rule to switch on two lights...
Attached the screenshots.
Am I doing something wrong?
Thanks in Advance
Comments (8)
Rick,
Try using variable time puzzle blocks like below....
That can't work. Your schedule runs every day only once time at 0:00 o'clock ;-) You have to choose repeat per minute or hour, but I'm not shure what's your goal?
I just just like to start a scène daily at the same time.
Then remove the IF - ELSE PUZZLE you don't need it, the scheduler will trigger your rule.
Ok thanks Alberto I Will try
Try something simple like this, in your case remove the IF puzzle and replace the action for TRIGGER SCENE
Hi Rick. It looks like your plan was also to run an OFF scene at a later time.
Then you would need to create a second rule as Albertos example with a time schedule trigger for the OFF command.
// Henning
Thanks to you all, great community this is!
I was thinking too difficult I guess. It is working right now. With a second rule for switching it of, indeed!
Thanks, Rick
