Unable to join Fibaro FGS-211 (switch) / FGD-211 (dimmer)
My Fibaro switch and dimmer where part of another z-wave network so I guess that is why I'm unable to join them to the Zipabox. I tried the reset procedure, but somehow I can't figure out if I'm doing it correctly. I follow the procedure from the fibaro manual:
2. Resetting Double Relay SwitchDouble Relay Switch provides two methods for resetting.
Method I : Reset by removing Double Relay Switch from theexisting Z-Wave network. The device may be removed using thecontroller that has the ability to include/exclude devices from/toZ-Wave network (see the manual of controller).
Method II : Within 5 sec. after connecting mains voltage supplyDouble Relay Switch allows the user to reset settings by singlepressing S1 key and then holding key S2
Solved my own problem, but am interested in other ways.
After trying multiple times to reset the modules, I found my old Aeon Labs z-stick and it sure makes removing devices a breeze. I used the following procedure from the manual and afterwards paired both modules to the Zipabox. Inclusion was almost instant! Yeah!Z-Stick procedure:
http://zwave-products.co.uk/online/templatemedia/all_lang/resources/Instructions+-+Aeon+Labs+Z-Stick+Series+2.pdf
