Updating meter attribute descriptions
David Pritchard shared this problem 12 days ago
I know it seems useless to report these minor bugs when larger problems are never fixed, but here we go: when you change the description of a meter attribute, in the rules where the attribute is referenced the description is never updated. So if you have one attribute called x and another called y, you make a rule referencing attribute y, and then realise the names should be swapped around, your rule will still appear to be using "y" although it's actually using "x". Confusing, to say the least. Worse, there's no way to know what the rule is actually accessing, so after a while you might not know how to fix it.
Comments (1)
Better still, even if they fix it, I can't update to the new firmware. So I don't know why I bother.
