Use of the virtual Weather Station
Michel CHEMLA shared this idea 5 years ago
I would like to use the virtual Weather Station to adjust the filtration time of my pool.
For that, I use a Fibaro FGS211 connected on the programmer.
The switch works fine.
I have created a rule where I change the state of the switch depending of the temperature and the hour.
The point is I have indicated 4 different temperatures (36, 30, 25, 20°C) and, in my rule, the time is always the case less than 20°C.
Is someone can help me to find the mistake?
I use the parameter Temperature_max with the condition >= 36 (by example)
I join the rule to the post.
Thank for your help
Michel
Comments (3)
The virtual weather station is used for the management and all goals for the field. Work of the weather station and law essay help is done for the flow of theocrat for all goals. The virtual station is embraced for the citizens for the embarked for the individuals. The virtual station of the weather is here for the testing and expansion for the fur times.
This service is very affordable and is designed to help students prepare and complete the final project according to their standards papernow.org. The service is also designed so that the student gets the most out of the academic writing service that the essay service offers.
Thanks to the author for writing the post, it was quite necessary for me and liked it. I wrote a note on the https://essaysservicesreviews.com/dissertation-service-review/ about this. I will be happy if you read it and accept it. Thank you for your concern.
