Utiliser la zipatile pour contrôler jeedom
Marc LE Port shared this thanks 8 months ago
Bonjour,
Je voulais savoir comment peut on controler ma box domotique à l'aide de la Zipatile ?
Merci
Cordialement,
Comments (6)
Personne pour m'aider ?
Toujours rien ????
Bonjour,
Perso je fais des virtual device et je commande jeedom avec les requettes http
Bon courage
@marc this meant more for zipato users than official Zipato support to comment on.
Personally I never noticed this post until now.
What are you trying to achieve, isn't Jeedom basically a controller like Zipatile? What do you want to control and why?
Or do you just want to use the Zipatile as a wall mount tablet with Jeedom UI?
@Christophe Sanges , merci je vais explorer cette piste.
@Adrian Van Der Heijden
I especially want to be able to drive my jeedom system with the zipatile. as you say, the zipatile would serve me as a wall tablet.
In that case, simply add the Jeedom apk to the Zipatile and install it. Just like any other tablet, but remember that it doesn't support Google Play services, so any notification service that Jeedom use that relies on Google services will not work. Also updating apps requires you to do this manually via apk downloads. Or add a 3rd party apk store like AIO Downloader.
You will of course need to register the Zipatile and become a registered user, but then you may be able to use the internal sensors and HTTP commands to connect them with your Jeedom system.
